Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 11-15-2012, 02:25 PM
Ketzer's Avatar
Ketzer Ketzer is offline
I ended up buying one from Metro Lifts off ebay. I have been very pleased with it so far. It has all the adjustments and stops everyone talks about. Was $975 plus shipping.
Jeff-
Old 11-15-2012, 05:16 PM
cencalc6 cencalc6 is offline
Originally Posted by Sparks67 View Post
It is too bad that you are in CA. I have a whirly Jig Pro that I like to sell. I have all the accessories for first gen Camaro. Mount stiffener and Camaro brackets. As for the hydraulic cylinders, then you have to buy some new ones. We used the harbor freight ones, but I think we had to replace 3 of them. Anyway, here is the company. http://www.whirlyjig.com/ Shipping would be to much, based on the current gas prices.
http://www.whirlyjig.com/comparison_...jig_models.htm
One thing nice about the whirlyjig is that you can turn the car, and lock into place with the shure lock. So, you are not limited by the angle, so you can do 180 or 270 or what ever you want. The other Rotisseries don't seem to have this feature. For example, the photo below is locked in at that angle. You don't want to spin freely. I sell it for $1100 with all accessories. Can you buy a cheaper one? Yes. Whirly Jig is the only rotisseries that keeps the car in parallel, basically you have 2 bars for support. See the other rotisseries use a single bar for support.
You did a very nice job on the floors
Jeff-
Excellent Fab work on your project
Going to try and find one locally to save on shipping
Old 11-15-2012, 05:49 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Thanks, I post my thread up again. We have close to 2 years in the floors. That Whirly Jig is great, because of the ability set it different degrees of rotation. I had this little craftsman stool, so it made it rather nice. My one friend gave a several different grinders to use, but at times it look like I was porting heads.
Good luck!
Jeff
Old 11-15-2012, 11:12 PM
youthpastor's Avatar
I've got an extra I bought off of Mr. Weld a few years back. It's ugly, very heavy duty, but shipping might be an issue
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 11-16-2012, 07:28 AM
Ketzer's Avatar
Thank You! I've never done a project as major as this. I am learning as I go.
Mine has the long threaded rod with a hand wheel on top for adjusting the "balance". This works really well. Mine also has the spring loaded pin that goes through holes in a circular plate every few degrees to hold it in any position. Both are really neat features you should look for if you can.
Jeff-
Old 11-16-2012, 10:44 AM
Sparks67's Avatar
Jeff-
Yes, you have the copy cat brand. Whirly Jig is the one designed it and every other brand has copied their ideas. Threaded rod is to make the unit spin and keep balance. Whirly Jig was the first to design that feature.
Here is the list of features to look for in buying a Rotisserie.
http://www.whirlyjig.com/GTO.htm
Jeff
Old 11-16-2012, 05:41 PM
snappytravis's Avatar
snappytravis snappytravis is offline
I built mine, (man ego) I ordered two or three joints of 2x2 tubing, and some 3" I also went to harbor freight and bought 2 long range bottle jacks, they are probably 40 a piece or so, then casters, I used the old shackles to mount to, and made brackets for the front that mount to the subframe mounts under the cowl, I probably had 600 or so in it, It works great but here is the deal, do you want to spend a bunch of time welding up the rotissiere or working on your car I would say that I had probably 30 hours or so in it, If I was to do It again I may just order it, I think you can get one from summit that isn't painted, for around a 1000.00 or so, If you don't need to turn the body completly over I also built a body cart that mounts in the rear shock area and then has pins that go into the front body mount holes as well, It took about 3 hours to build, I think if you look at my build thread you can see some pics, good luck
Old 11-18-2012, 06:15 AM
Thank you for the great tips and suggestions
