Old 11-18-2012, 07:18 AM
Surfman423 Surfman423 is offline
Originally Posted by MarkM66 View Post
It'll fit on a stocker, but it won't be able to sit low. No way that will tuck under the wheel house. Just depends on what's more important to you.
My plan is to drop it 2" with a Hotchkis TVS kit. Would a 20x8.5 be better or should I just stick with 18" all around?
Old 11-18-2012, 08:48 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
18" all around is the way to go. 20" is way to big and ends up goofy looking IMHO.
Curtis
Old 11-18-2012, 08:57 AM
Doctor Fresh will be unfriending you on facebook in... 3... 2... 1...
Old 11-18-2012, 01:35 PM
FETorino's Avatar
FETorino FETorino is offline
Hmm put me on that list although I do like an 18/19 combo like Mark did on Mayhem.
Rob in SoCal
Old 11-26-2012, 11:00 AM
Sparks67's Avatar
Sparks67 Sparks67 is offline
The rear should be 19" and front is 18". I have 18" all the way around on my 67 Camaro, but the 19" on Mayhem seems to fill the wheelwell better.
Old 12-04-2012, 04:48 PM
mario65's Avatar
mario65 mario65 is offline
My 67 Bird
18x8 and 18x10.5 no tub
And I could not be happier
http://forums.performanceyears.com/f...d.php?t=714841
the most perfect fit would have been 4 13/16 BS front and 5 7/8 BS rear
Big sway bars and perfect bump stops keep you from worrying about rub.
285/40/18 has the perfect height and width for a 67 F body.
1967 Firebird 400 with Nunzi 467 frame off, 04 Black CTS-V stock,
2011 Ducati Diavel Carbon, 2003 Ducati ST4S, 2000 Confederate America GT, 1978 Bandit T/A W72, WS6, 4speed hardtop.
TRANSAMS.NET
Old 12-05-2012, 08:06 AM
67rstbkt 67rstbkt is offline
Originally Posted by mario65 View Post
My 67 Bird
That looks awesome!!! Nice work
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
Old 12-07-2012, 07:43 AM
onevoice onevoice is offline
My 67 Bird
Well done, and this fitment shows that there is more than one way to skin a cat.
Your example illustrates that the key to getting the proper look is how the tire/wheel fits the wheel opening, not necessarily how low the car is. The 285 is nominally about 27 inches tall. The larger diameter lets you fill the wheelwell without having to run so low. Anyone looking to duplicate could go as small as a 9.5 inch rim width and still be inside the manufacturers recommendations. The bumpstop is an important part, because that tire/wheel isn't going to tuck inside the wheelwell.
