Old 11-28-2012, 05:47 PM
sds machining's Avatar
sds machining sds machining is offline
Originally Posted by mlcurl View Post
Awesome build. How do you like the ISIS system so far? We are thinking of using it in our next build but have heard both good things and horror stories about them. What all are you using it to control?
We have the entire car controlled by ISIS, using the IMax touch screen, In reserve, In motion, etc. The first time installing the system is a bit challenging but the Tech support is great. disregard anything you may know about wiring and go into it with an open mind and be prepared to ask questions. its a great system and i would use it again. You will need to be very specific in what you want to control with the system, and more then likely you will need more then just the 3 cell kit. There is a learning curve involved but like i mentioned everyone as ISIS is very responsive and helpful.
