Old 12-06-2012, 02:55 AM
rocketrod rocketrod is offline
Originally Posted by JKnight View Post
The combination of a tall ball joint and Ridetech tall spindle will make for some very strange suspension geometry. I think you're going to need to spring for some new ball joints at a minimum. Even then you'll have the potential issues Bret outlined earlier.
I will definitely need to get new upper ball joints and just mock things up.
I am not concerned with getting the car aligned as I have the SPC Fastrax alignment tool and it is pretty simple to align once you get the hang of it, or should I say much easier than adding shims.
Rod
1969 Camaro - LS2/4L70E
Old 12-06-2012, 05:12 AM
itsals1 itsals1 is offline
Rod
Keep us in the loop on how this is working out for your camaro! I will wait to order parts, pending your results!
Travis
Old 12-06-2012, 05:23 AM
Originally Posted by itsals1 View Post
Rod
Travis
No problem......I just need to figure out what the part number is for the Howe upper ball joint I need.
Rod
