Old 12-13-2012, 09:41 AM
AmKenpo1's Avatar
AmKenpo1 AmKenpo1 is offline
I've heard some of the same recently Jason. Can you explain to me the difference between the True Trac and the S-Track? Also, any comments on your past history testing w the Wave Track? Appreciate the input...!
Ron,
Both the TrueTrac and the S-Track are helical gear differentials. The S-Track for the 9" is designed with more internal gears which allow it to spread the load over more area, giving it better power handling. We have seen the S-Track in a Low 9 second 2800Lbs. drag car that drives to the track and home. The S-Track also has a Lifetime Warranty. I hope this helps.
Wil.
Strange Engineering
