Old 12-14-2012, 08:26 PM
69x22's Avatar
69x22 69x22 is offline
Default 4L80e shifter suggestions
Other than the paddle shifter can you guys post pictures or make suggestions of a good shifter that is in style for these transmissions.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 12-14-2012, 09:29 PM
transam's Avatar
transam transam is offline
I have a 4l60 in my car, i picked a trailblazer ss stock shifter for it,i believe the tbss has a 4l70 but i would assume a 4l80 would work with it as well
Old 12-17-2012, 01:03 PM
Steve Chryssos's Avatar
The shift gate spacing from 4L60E's(and 65, 70) is different than the '80Es and '85E. It's just enough to throw off smooth function. This is especially true of the gap between park and reverse. It's wider on the 80E/85E. When using a more common '60E shifter on a car with an '80, it is possible to have a friend in the car move through the positions while you adjust the cable underneath for best compromise. That usually means engaging park but not 1st.
It's not impossible to use a shifter that is marked for use with a 700-R4, or 4L60E on a car with an 80E, but it is advisable to choose one with the correct 80E gate spacing. Lokar seems to have the best aftermarket selection of 4L80E specific shifters.
________________
Steve Chryssos
Ridetech.com
Old 12-18-2012, 12:13 AM
alky alky is offline
Hey Steve, would a TH400 have the correct detents on the shift gate if not using 1 St gear? I'm in the same boat too looking for a shifter but I have a good working Hurst for my TH400 now. Race ready products has a nice one for $265
Denny
Old 12-18-2012, 12:20 AM
Race ready products
Old 12-18-2012, 03:06 PM
I like the Race Ready shifter. Very positive action without any "pull up/push down/slap yer knee twice" lock-out nonsense. And they do make a 4L80E version. The only downside is that it is very large.
I'm not sure about the TH400 gate spacing as I've always tried to make the 700R4 4L60E stuff work. That would be a definite maybe.
________________
Steve Chryssos
Ridetech.com
Old 12-22-2012, 05:44 AM
69x22's Avatar
Thanks for the suggestions guys. B&M makes a Quick Silver for the 4l80e. We are going to run a console so what we will probably do is make a more stylish shifter arm for it since thats all that you will see.
1957 Chevy 454LSX
Old 12-24-2012, 08:36 PM
kustom71 kustom71 is offline
I used a shifter from a 4th gen fbody.I did have to adjust it a couple times but it goes in every gear.
71 Chevelle(under construction)
Vortecpro 475BBC
4l80 Homebuilt(with alot of help from Jakes performance)
12 bolt-4.10 gear
Old 12-24-2012, 11:20 PM
realcoray realcoray is offline
I'm going to be using a B&M stealth pro ratchet. There aren't many options but this was relatively cheap and looks nice.
