Old 12-20-2012, 08:34 PM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Originally Posted by Blake Foster View Post
consider the wheels are actually 12 and 13" wide respectively
so an 11" wheel with 5" back space has 7" on the front side. total width 69"
a 12" 6" 7" on the front side. total width 71"
one of your combos is not going to work being the rear end width is 2 inches different.
our car has 12 with 5" bs and a 54.5" and will need small spacer for a total width of 69 +/-
hope they both work out
Well Im @ a 6''BS on the rear, 57'' flange to flange. You are at 5'' @ 54.5''. Correct me if Im wrong but you add an in from both side to compensate for the bs difference and it would be 56.5'' F to F. Thats a 1/2'' difference that can be made up in the wheel well. I should have a 1/2'' on each side. With a 6'' lip on the outside and a 57'' housing that puts me @ 69''as well. PLease follow up with your opinion or input. Thanks-K
Resources I used:
http://www.pro-touring.com/showthrea...te-almost-done
Old 12-28-2012, 05:57 PM
Blake Foster's Avatar
Resources I used:
it's all in the tape meassure. math adds up.
Blake Foster
www.speedtechperformance.com
