Old 12-16-2012, 12:11 AM
Lenie's Avatar
Lenie Lenie is offline
I had my whole exhaust system (headers back) Jet coated, still got hot so now I've wrapped my exhaust w/header wrap and custom stitched a heat blanket fot just the top of my mufflers. Haven't installed them yet but should in the next couple of days, I'll let you know how it goes. Good luck. Thanks for the advice Ron.
Lenie
Old 12-19-2012, 08:16 AM
frankv11's Avatar
frankv11 frankv11 is offline
Ron
I've gone back and changed those sharp angles at rear, I did'n like them either was just being lazy.
Old 12-19-2012, 09:00 AM
Ron in SoCal's Avatar
That looks killer Frankie
Ron in SoCal
69 Camaro in progress
Old 12-19-2012, 09:28 AM
cencalc6 cencalc6 is offline
Very Nice Job Frank!
Old 12-19-2012, 10:17 AM
CarlC CarlC is offline
I'm sure you could get there with math, as well.
0.461" for 304SS
The other part to consider is that all sections get longer, that means some sections of the tube structure will get wider as well. Flexible hangers come in hand for such things.
Very nice tube fabrication!
http:www.vaporworx.com
Old 12-21-2012, 08:32 AM
frankv11's Avatar
Originally Posted by CarlC View Post
0.461" for 304SS
Thanks Carl , I will be in contact. going to be needing control module for Vaporworks tank.
got to figure out how to quote multiple comments, any how thanks phil and Ron " We need up dates on both builds"
Old 01-21-2013, 09:32 PM
makoshark makoshark is offline
Originally Posted by frankv11 View Post
You are absolutely correct but I have a trick up my sleeve for that
That was something else that I thought about but if I run bracket on exhaust and another on body w 3/8" bolt to hold grommet together. It will not give it room to grow. I'm trying to guide the expansion by way of hangers so it will not compromise the close tolorances to body at certain places.. I have the whole system tucked in there pretty tight. For now it's just theory I'll see how it behaves once I put some heat to it..
Good eye
Cut a groove in the rod and snap a c-clip on it to hold the grommet in place.
By the way, I'm still contemplating on stealing your exhaust idea
Old 01-21-2013, 09:49 PM
Those sure are pretty, Nice job.
Old 01-21-2013, 10:16 PM
frankv11's Avatar
That will hold the grommet together but would not let exhaust slide back and forth freely. I'm thinking something along the lines of safety wire..
No need to steal. I'm willing to donate!
Thanks Wayne. Hope all is well with you, how is that project coming along?
Old 01-22-2013, 04:23 PM
Thanks Wayne. Hope all is well with you, how is that project coming along?[/QUOTE]
Thanks for asking. Pretty slow right now but getting ready to get back on it.
