Old 12-22-2012, 03:44 AM
69x22's Avatar
69x22 69x22 is offline
Thanks for the suggestions guys. B&M makes a Quick Silver for the 4l80e. We are going to run a console so what we will probably do is make a more stylish shifter arm for it since thats all that you will see.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 12-24-2012, 06:36 PM
kustom71 kustom71 is offline
I used a shifter from a 4th gen fbody.I did have to adjust it a couple times but it goes in every gear.
71 Chevelle(under construction)
Vortecpro 475BBC
4l80 Homebuilt(with alot of help from Jakes performance)
12 bolt-4.10 gear
Old 12-24-2012, 09:20 PM
realcoray realcoray is offline
I'm going to be using a B&M stealth pro ratchet. There aren't many options but this was relatively cheap and looks nice.
