Old 12-22-2012, 05:16 PM
Can you post a picture? You want to make sure you get your feed from the correct line.
Old 12-23-2012, 06:21 AM
cp87 cp87 is offline
Here is a pic of the Y block, 2 lines and 1 line out. I have no idea why it's set up like this.
Old 12-23-2012, 10:08 AM
You need to use the attachment option for the pic to show.
Old 12-23-2012, 10:18 AM
Old 01-07-2013, 10:57 PM
disconnect one line...see which one pours fuel.
I'd get rid of that and go one line to the pump.
Old 01-23-2013, 11:46 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Default Air leak
It sounds like you have an air leak somewhere along your lines. try to see if you lines alone will hold a vacuum. Disconnect them at the rear sump (obviously, cap those), then see if you can pull a vacuum on your system. The interior of the lines/hoses behave differently under a vacuum than under pressure.
My customer's 66 'Stang had a short line (1yr old) that was collapsing inside & doing just about the same thing, but at random intervals.
