12-27-2012, 10:14 PM
On to the rear end coilover setup. I removed my factory upper spring bucket brackets first. I then installed a crossmember after many measurements were taken. This crossmember was inset into my frame with a holesaw, instead of flush mounting it, on each side for strength.
I then braced this crossmember to the factory crossmember diagonally.
12-27-2012, 10:25 PM
12-27-2012, 10:41 PM
12-28-2012, 10:00 AM
damn, looking good! I really wish I had done this to my chevelle. I didn't put a lick of stiffening to it other than a roll cage....
Doug
1970 chevelle, 383/turbocharged/carb'd/5 speed.
12-28-2012, 12:02 PM
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
12-28-2012, 04:24 PM
Originally Posted by 214Chevelle
Thanks man! I love your build. It was one of the first I looked at on this site.
12-28-2012, 04:22 PM
Thanks Dug, I am going to try a "big bar, soft spring" setup that used to work well for me when I raced NASCAR late models. I am gonna dodge some cones, and being as how these a-body frames are as flimsy as a fly swatter, I figured I better try something. I might cage this car also, which would really add a lot of stiffness. I'm on the fence with the cage, due to the weight. I've already added more weight than I wanted to.
01-25-2013, 02:21 PM
didnt see this before, doh! I like everything else you're doing and progress is definitely happening. Thats great. keep at it.
Doug
01-25-2013, 02:28 PM
Thanks Doug! Will do.
07-04-2014, 11:25 AM
Hey Scott. Your build is awesome and a great inspiration. I have a 69 Chevelle and wanted to do the same type of thing you did to your frame. Did you self bend all the tubing or do you know of a kit i could get. Again, the build looks wicked. Keep up the great work.
-Andy
Andy Kacura-Miller
| Thread Tools |
| Display Modes |
Hybrid Mode
