Old 12-29-2012, 12:40 PM
Fitter48044 Fitter48044 is offline
Looking for wheel suggestions. What do you all think of these?
or
Old 12-29-2012, 12:45 PM
The first IMO. What color are you painting the car or will you keep the factory paint? I think the spoke color will look good against the red of the car. However, I'm afraid the gold and bronze in the stripes and decals will clash. It'll be too many different colors that are similar on one car. Again, just my opinion though. I like the wheel design regardless of color.
Old 12-29-2012, 01:14 PM
I plan on the factory paint or something very close. I was worried about the gold and bronze clash myself. May look at the satin gun smoke center and a brushed outer.
Old 12-29-2012, 05:25 PM
That may match the stripes a little better if you plan to put them back on after the repaint. Also, keep in mind that you can always change the color of the rim centers. It's just paint so don't think you're limited to what the wheel company offers. The important thing is to get the finish on the metal correct the first time, be it a brushed lip or polished lip. Changing the metal finish would cost a lot compared to simply repainting the rims a different color that matches the stripe or paint better. Regardless, I like where you're going with the car that's for sure.
Old 12-30-2012, 08:04 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
I wouldn't worry one bit about modifying this car even if was a 2k survivor. It's YOUR car, enjoy it as you please. And, as mentioned, they did make a lot of these. Understood that you bought a solid car to have a good foundation (which is smart, wish I had done that..), but I wouldn't shy away from some more permanent mods, especially if not doing them will hinder you from getting the end result you want (a high performning/ good handling car).
As for rims- I also vote for the first one you showed (the 2 tone)
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 11-08-2013, 04:47 PM
SO after a long and thought out break, I'm changing directions with this car and leave the car as is and look for something new.
Old 11-08-2013, 04:48 PM
Hope to update this thread when I find a clean shell to start with.
Old 12-29-2012, 01:54 PM
onelapduster onelapduster is offline
For the money you could get for this 2,000 mile survivor, you could get a roller with a done body to put the suspension and motor in. It just doesnt make sense to mod a car with such low miles. There were hundreds of thousands made so it can be seen either way i guess. Good luck with the project!
Old 12-29-2012, 02:52 PM
The car has 20,000 miles on it. When I tried to correct the thread on Nasty Z28 it was deleted. Based on the feedback I was getting I figured that it wasn't worth while to try and explain the typo I made.
Old 12-29-2012, 04:48 PM
That would certainly change some minds. Its a really nice car to start with. Look forwad to seeing the transformation! Those wheels will set it off more from the plain stock wheels on it now.
