Old 01-11-2013, 10:47 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
Originally Posted by BBC71Nova View Post
I had my bbc w/t56 just mocked up in my oe frame using big block frame stands with the correct offset and the ATS crossmember. It did seem to fit good.
Previously I tried an older set of repop frame stands that were Listed as big block stands and that didn't work. Those stands had the driveline sitting a little farther back and outside the range of the ATS crossmember. Those frame stands also had other issues with my setup. I dont think they had any offset to them.
Anyway, dimensionally I think you may be ok. My only less than great comment about this crossmember is it seems to flex a lot. Mute point for me now since I'm moving drivetrain back which will require custom crossmember
Thanks John for the feedback. Glad to hear it fit okay for you in a similar setup(I have an OE frame also). Seems like it would just by looking at it. I'll know for sure next week. I can see how it might flex. That could a be a bit of an issue considering my new ZL489 motor should be fairly stout.
What HP/TQ numbers were you seeing that caused the flex? Do you think the main source of the flex is from the side brackets(which I might be able to strengthen) that bolt to the frame, or the bar itself?
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 01-11-2013, 11:31 AM
rchaskin's Avatar
rchaskin rchaskin is offline
I would have to say the flex he is talking about is up and down bounce.
Mine does this also. (My car is SBC & LT1 style T56)
I added some gussets from the downtubes to the bottom plate and it did not help much.
I currently have mine trans out, and will be adding a full 3/8" plate to cover the entire bottom of the bottom plate. There are so many cut outs in the ATS plate it just flexes.
---I am not saying that this is a bad part or anything, because it fits perfectly, just a little bouncy for me---
Good luck
Randy
Old 01-11-2013, 11:45 AM
chr2002ca's Avatar
Good luck
Randy
That's great info. Thanks Randy. I might as well do the same while it's out.
Chris Robinson
Old 01-11-2013, 03:43 PM
Blake Foster's Avatar
Thanks for making the Call to talk to us about your concern.
Blake Foster
www.speedtechperformance.com
Old 01-11-2013, 11:37 AM
chr2002ca's Avatar
Just spoke with Speedtech by phone and they mention that this restriction is related to more easily setting pinion angles, not with the crossmember actually fitting. As long as you shift the crossmember to the passenger side by the same amount that the BBC frame stands do(3/8"-1/2"), you'll get the proper straight alignment for the engine/transmission to match the alignment of the rear diff, hence getting the left/right pinion angles to match on the driveshaft u-joints. Speedtech said the crossmember is left/right adjustable which makes sense due to the slots on the bracket, so this should not be an issue. Also, you have to deal with the up/down pinion angle caused by the height of the BBC frame stands, and that's something I was already aware of and realize some trans tunnel modifications might be in order to get the transmission high enough in the rear to get a minimal and matching up/down angle with the rear diff.
So Speedtech's restriction in their instructions is more of a warning than an absolute.
Chris Robinson
