  #24
Old 01-13-2013, 03:52 PM
pjs65 pjs65 is offline
I have fitted a TKO600 with the 0.82 5th and its ok , its not perfect but feels like a tough gearbox and works good on track and i like it . It shifts quite well and i have not had the 2nd to 3 rd problem that other people have , it also weights a bit less than a T56 .Its a noisey gearbox and sounds like its got straight cut gears , also reverse can grind if you try a bang it in . Having used the 5 speed i think 6 gears are too many and i only use 5th on the fast straights when taking it easy . The Dart 400 sounds nice , plenty of grunt .
I have managed to adapt some BMW M5 brakes for the rear axle and it looks like a good setup . We in Europe dont have to many LS Camaro's to take rear brakes from but have loads of BMW around to rob parts from , when i have mounted to brakes i will put up some pictures .Pete
