Old 01-30-2013, 07:30 AM
Wissing72's Avatar
Wissing72 Wissing72 is offline
it looks odd but maybe this will help? 50.00 or so in plywood and a jigsaw...
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
Old 01-30-2013, 07:32 AM
NvrDun71 NvrDun71 is offline
04-06' GTO spares if you can find them for a good price, which is getting harder to do these days
71' Nova - LY6, T56
Old 01-30-2013, 07:40 AM
Gaslight Gaslight is offline
I have these for sale if you are interested.
http://inlandempire.craigslist.org/pts/3561041377.html
Jake
1973 Nova SS
Old 01-30-2013, 07:45 AM
randy randy is offline
if the 5th gen wheels are new then buy them. once you are finished resale
Old 01-30-2013, 12:55 PM
Apogee Apogee is offline
Those are sweet! ...and you can stack them up and store them anywhere when you're done.
Tobin
KORE3
www.kore3.com
Old 01-30-2013, 01:59 PM
NOPANTS68 NOPANTS68 is offline
I ran into the same issue. I just pulled the calipers and bolted on some slot mags I found for 50 bucks. I'm running C6 Z06 Kore3 gear on a chevelle.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 01-30-2013, 05:02 PM
intocarss's Avatar
Why not make something like these?
Old 01-30-2013, 07:01 PM
IMPALA MAN IMPALA MAN is offline
I built this for less than $350. It bolts together, is made of 5 X 5 square tubing and allows me to work under the car if needed.
Old 01-30-2013, 08:20 PM
Firebird-Geek Firebird-Geek is offline
I actually own a set of "skates" for moving the car around the shop... Just don't own any wheels to set the car on the skates... it came with 15" cheep aluminum wheels with 7/16th wheel studs... I now have 1/2 wheel studs. So these would neither clear the brakes, or bolt up to the car without drilling out the wheel studs... not sure if a person can do that effectively?
Someone said S10 compact spares (94-02) work with larger brakes...??? My brakes are 13" Wilwoods up front 12" in the rear.
1967 Firebird Convertible
Jarrod
My Build:
https://lateral-g.net/forums/showthread.php4?t=32878
Old 01-31-2013, 09:34 AM
There are two common type of lug nuts used on muscle cars, 60 degree conical seat and shank type, both of which are readily available in 7/16-20 and 1/2-20 sizes and can be found for cheap.
Tobin
KORE3
www.kore3.com
