Old 02-07-2013, 07:39 PM
intocarss's Avatar
making progress..... but I am in line behind this thing... 781 cubic inch.
I am back in the queue early next week Mike says.
Makes ya feel inadequate don't it
Exact same CI that my Freightliner has! OMG!! I almost passed out when I saw this bad boy... Nothing better than a big azz motor on a dyno. Bet she shakes the whole building. Ya gotta be there when they run it and post video!!!!
We dyno'd some big cubic inch engs and well... you just have to be there to know the feeling.
Old 02-11-2013, 12:00 AM
Richio1's Avatar
Richio1 Richio1 is offline
Diggin the rendering Dave. As you said, sure helps in visualizing the final outcome. Looking forward to seeing it come together soon.
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 02-11-2013, 12:54 AM
Thanks!
Had a great weekend. Went to the NASA event at Sonoma Raceway (formerly Sears Point/Infineon -- Happy, Greg?) and hung out with the Life's Good Racing team who field an awesomely quick 69 Camaro that is well known around here. Got some great ideas from that car and talked with the team quite a bit. The car is relatively simple other than the Lateral Dynamics 3 link in there.
Then today Rich and I pulled all the suspension out and got it on the body cart he put together.
Gotta take a step back to take 2 steps forward. Or something like that.
Should have some updates this week on engine, and should take delivery of the floater rear and spoilers from Jake.
Old 02-11-2013, 01:15 AM
fleetus macmullitz's Avatar
Thanks!
Jake Blues: "Car's got a lot of pickup."
Old 02-11-2013, 09:03 AM
Track Junky's Avatar
Hey, if your going to get rid of your old rear spoiler let me know.....I dont want to cut my original one up.
Gaetano Cosentino
Old 02-15-2013, 02:54 AM
Yes, yes it does.
It's yours buddy.
Old 02-15-2013, 03:06 AM
Received another NASCAR part today... Somewhat experimental (for me, not the part itself). I have always wanted to try a locker and now I will do so. Who knows, I may really like it. If not, I'll swap in a Tru Trac.
This is a Roush Yates Detroit Locker Cup Car take out.
Nodular case
3.25 big bearing
Daytona pinion support
3.64 gear ratio (the ratio I was looking for)
Gears REM polished
Gears scalloped/lightened
G-Force internal pump
1350 billet yoke
All this for under $1000 shipped to my door. And looks to be in excellent condition.
This 3.64 rear with my T101A trans will put me around 67-70mph top speed in 1st gear and 150-160 mph in 4th, depending on final redline of motor (figuring 7200-7500).
Also, the Fab53 "Chain Saw" tow hook was a little worn and has been blasted and will be cleared before reinstall.
Got a pallet on its way from Jake.... pretty stoked for what's coming.
Old 02-15-2013, 09:31 AM
It's yours buddy.
Hope that locker works out for you
Gaetano Cosentino
Old 02-15-2013, 09:38 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
I think you did good with the buy on this third member.. If locker does not work then you can swap posi unit... I have one of these units on order..
[QUOTE=Flash68;464775]Received another NASCAR part today... Somewhat experimental (for me, not the part itself). I have always wanted to try a locker and now I will do so. Who knows, I may really like it. If not, I'll swap in a Tru Trac.
Nodular case
3.25 big bearing
Gears REM polished
1350 billet yoke
Cris Gonzalez
Old 02-15-2013, 10:01 AM
Sieg's Avatar
Sieg Sieg is offline
Dave - What are the performance traits of the Locker that could be a negative in your application?
