Old 02-09-2013, 06:09 PM
'Cause it is....
I didn't do any of the set up - it's just the paperwork that came with the car.
I'd bet you all you have vs. what I have that it's with driver and you should get your car back on the scales to get the cross weight right.
Old 02-09-2013, 06:13 PM
I'd bet you're right.....
It spins both ways so what's the problem??
Old 02-09-2013, 06:18 PM
Here's my old car on the scales with dead nuts cross weight and me in the car. Notice the left side vs. right side weight. Very similar to your car. You just need some work on the cross weight. From my fuzzy memory, your RF spring needs a few turns UP.
Old 02-09-2013, 06:20 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
You bring up a good point.
Thanks for the effort Greg. Sounded like a lot of work. You should count it towards your daily amount of exercise.
Old 02-09-2013, 08:51 PM
headcase headcase is offline
I still don't get it. A big dodge charger weighs 3400-3600lbs depending on options. Why on earth would a car half the size weigh almost the same. Alloy engine block and heads, coil over suspension, Carbon fiber interior, alloy wheels, billet breaks, alloy cased gearbox... Gotta weigh under 3000.
Old 02-10-2013, 06:16 AM
DTM Racing DTM Racing is offline
We weighed our 65 slow back, full interior with a new 5.0 roller motor/T-5/Ice Cream Truck rear and it came in at 2888. I dunno what you did to make a race car so portly. Cage?
Old 02-10-2013, 06:42 PM
bret's Avatar
bret bret is offline
Supporting Vendor
My 69 with an iron block/aluminum head 351W based 460, magnesium Rankin trans, carbon clutch, rollcage and no back seat weighs 3100.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 02-11-2013, 06:29 AM
Bryce Bryce is offline
my 65 falcon weighs 2700lbs, fiberglass front end, no rear seat. And some aluminum stuff.
The 65 drag car weighs 2600lbs, all steel, full interior. Everything bolted onto the car has had weight reduction in mind. But the wheels and tires alone are 75 lighter than the one on my falcon.
