Old 02-11-2013, 09:30 AM
Ketzer's Avatar
Ketzer Ketzer is offline
After seeing so much of your incredible work on here, I cannot believe you need someone else's measuring tool? I fully expect you to have your own super-cosmic, high speed/low drag fixture for this...
Jeff-
Old 02-11-2013, 10:35 AM
dontlifttoshift's Avatar
JCG has them in billet. With 3 legs if I remember right.
Then there is this one http://wheelworksinc.com/ with two legs.
I haven't used either one but I can absolutley see where it would be really nice to have around.
Donny
Old 02-11-2013, 11:25 AM
JasonElvisHeard JasonElvisHeard is offline
ok cool, thanks mang!
jason
Old 02-11-2013, 12:16 PM
carbuff's Avatar
carbuff carbuff is offline
I just used this tool to measure mine, and while it did the job, it's a very clumsy tool in my opinion. The way in which it assembles caused problems / interference right at my needed wheel/tires widths (10" and 11.5"). We had to disassemble and reassemble it a few times to get any adjustability in the ranges we needed...
If there's a better option, you may want to look for it. While this one worked, I wouldn't have wanted to pay for it...
In that last picture, you can see where the black wingnut was 'bottomed' out against the bracket on the very left. I couldn't just revert that l-shaped bracket because then it hit the other screw. I could put it on the other side of the big flange, but then it doesn't measure correctly. The first time I did that, I was off by 3/4". Thankfully we put it all back together again and realized I was miscalculating because of the flange being on the other side of the bracket...
Anyway, like I said, it was a little clumsy to use. I'm sure once you get the hang of it, it would be fine...
Old 02-11-2013, 12:30 PM
Ketzer's Avatar
Jason,
Just pokin' a little fun, no harm meant. Not only can you weld, your fab is some of the slickest I've seen posted on here.
My apologies.
Jeff-
Old 02-11-2013, 12:58 PM
Originally Posted by Ketzer View Post
Jason,
My apologies.
Jeff-
no worries, I was just giving you a little sarcasm back...
Jason
Old 02-11-2013, 01:00 PM
hit up JCG and no luck, he only made one and is not selling them. I will look into the one posted but if it is not ideal then I might have to design one myself. 300+ is a little much if it really is difficult to use for 10-11 inch wheels, right where I need it.
I don't have time to design one... I need to measure wheels now. Looks like the old fashioned method will have to do!
Jason
Old 02-11-2013, 11:23 AM
Jeff-
well clearly the lack of a nice wheel measuring tool indicates that I cant weld...
