Old 05-17-2006, 09:00 AM
markss28 markss28 is offline
I say the best for looks and function will be going with some 19s in the front and 20s out back. YOu cvant go wrong here because you can still put a bit thicker tire in the back fro that big block torque.
Bill Howell has this same set up on his GTO but 12" wide in the back I think.
check it out.
https://lateral-g.net/members/howell/
Never Stay Stock
Old 05-17-2006, 09:18 AM
GeorgeO924 GeorgeO924 is offline
is 12 wide enough or no?
Old 05-17-2006, 09:21 AM
jonny51 jonny51 is offline
Should be,you can run a 335.
Old 05-17-2006, 10:18 AM
Cool i have never had anything bigger than 8.5 but i had 2 1994 Camaros and a 1993 Cobra. Im new at the bigger body stuff got alot of research suspension wise to do lol.
Old 05-17-2006, 11:16 AM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
I'm pretty sure a 315 on an 11" wheel is about as wide as you can go on a '68-72. My '69 has a hair under 13" total width in the rear wheel-well, and the 315/30/17s I will be running are 12.25" - 12.5" wide depending on manufacturer..
Old 05-17-2006, 12:03 PM
Derek you would know better than me.I was just thinking what tire would work on a 12" wheel.I wasn't considering that it is a chevelle.
Old 05-17-2006, 12:42 PM
Hdesign's Avatar
Hdesign Hdesign is offline
George,
I like the direction you're going with this. I personally think 22"s are a bit much for Chevelles. To me, they look more at home on a larger car like an Impala. Once you get over 20" on an A-Body, they start to look like those little DUB toys or "Donk" style cars popular in rap videos.
The Chevelle/A-Body clients I've had in the past had a lot of luck with 18"s Front/19"s Rear. If you want a little rake, I've rendered cars with a taller sidewall.
As for rim choice: I prefer the Soft Lip/Fat Lip smooth hoop style to the stepped hoops. It has a more modern look. Boyds, Foose and Billet Specialties have a great selection of wheels. Have you also looked at www.introwheels.com ? I've been spec.'ing them a lot lately for my clients.
Gimme a shout if you want a rendering done! I can play with colors, graphics and wheels 'til you find the right combo. Check out the Artwork page for portfolio samples from all the talented artists on this forum.
Good Luck!
Ben Hermance
Hermance Design
My Facebook
Old 05-23-2006, 11:34 AM
USAZR1's Avatar
USAZR1 USAZR1 is offline
I'm pretty sure a 315 on an 11" wheel is about as wide as you can go on a '68-72. My '69 has a hair under 13" total width in the rear wheel-well, and the 315/35/17s I will be running are 12.25" - 12.5" wide depending on manufacturer..
Yep,unless you plan to tub the car. Anything over 30" diameter is really starting to push it,also.
I also think a 19/20 or 18/19 combo would look great. I'd love a pair of 19x14's and 355/25/19 Pirellis on the rear of my car.
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 06-29-2006, 05:33 PM
slownova slownova is offline
i find it amazing i missed this post. thanks for supporting my car guys haha. as far as rubbing, it doesn't rub the slightest. i think thats stupid to. i acctually built my car to drive, hint the reason i did 19s. 19in tires are unreal how much they cost. i could of done 20s in the front but with the bags lowered all the way down it would of rubbed. its close it both the front and rear, but it doesn't rub at all and ive driven the car at least 600 miles. i have about 4k invested in my intro rims and dunlop tires. as far as the tq and the skinny tire, i have a 496 with aftermarket everything and a 4 speed, i know all about it. i haven't had the slightest problem with my rims/tires yet. and thier right, build the car for you not everyone else. i think everyone was mad that a 21 year old kid was doing it and not chip foose or someone else, who knows. if you have any questions PM me, i'll gladly answer. i have a few other pics if your interested in seeing them. oh and the skinny sidewalls don't seem to effect my ride much being is im on air-ride. acctually it rides better then my 07 esclade.
Old 05-17-2006, 02:26 PM
nitrorocket's Avatar
First, DO NOT put wheels on the car that will rub at all. I see so many people do this just for looks. That is just stupid!
Make sure you can crank the wheels, hang a turn, or go over a speed bump.
As long as they do not rub, go any size you want. Wheels are a personnal choice.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
