Old 02-20-2013, 07:44 PM
jorgezee1 jorgezee1 is offline
Default spectra gas tank modifications
I have an old style spectra gas tank. out of warranty. this does not have the new baffle installed on it and it has starvation issues at about 1/4 tank. Can I modify the tank? weld a new baffle in? not me personaly but a shop. I am still running the stock pump does anyone have the walbro part number to upgrade this pump? I have searched and I did find some part numbers but it seems a few people have run different part numbers on these. can anyone confirm the pump they used?
Thanks,
Jorge
Old 02-21-2013, 07:50 PM
CFster CFster is offline
I believe Tanks Inc has a fuel pump with a built in tray on the bottom to serve as a baffle.
'67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
'67 GTO LS3 Swap
Old 02-22-2013, 12:40 PM
ok i will have to check out their site. is it a drop in for the spectra tank or universal? thanks for the info.
EDIT: I gave them a call part number PA-4 $235.00. looks like its a universal fit for any stock or aftermarket stock style tank.
http://www.tanksinc.com/index.cfm/pa..._id=6/art6.htm
I might try to modify my existing spectra baffle first and if I can't figure it out I might have to go that route. has anyone modified the tank baffle before? can it be done? and is it worth it?
Old 02-22-2013, 01:40 PM
fuel pump part numbers I have found.
AC Delco ep381 - spectra manufacture pump replacement - Amazon about 55.00
Walbro gss340 and gs341 still not sure which one is correct drop in. about 75.00
Old 02-22-2013, 08:48 PM
v8s only's Avatar
v8s only v8s only is offline
I have same tank replaced the pump with walbro gss 340 fits perfect
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
