Old 02-24-2013, 02:22 PM
MX145 MX145 is offline
Default Sandblasting dark spots left
On my 68 Camaro areas that originally had a little more than surface rust have dark spots after sandblasting. The rest of the car turned out great with the white/grey clean metal color. Do I need to keep sandblasting until the spots go away or use some type of rust conversion process before epoxy primer? I'm trying to avoid using a rust sealer product like POR-15 because I don't want to get the car wet with their metal clean and prep process while I'm working some other bare metal areas. Seems like a lot of pro builders use epoxy right over the media blasted surface and I want to make sure I do this correctly. The spots show up in areas behind the quarters and inner roof structure so they won't need finish paint work. What do you guys think?
Old 02-24-2013, 07:16 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
The dark spots are rust deposits still left in the pitting, it needs to be removed, or it will continue to corrode. after it's removed a two pack epoxy primer is the way to go.
Greg
Old 02-24-2013, 08:07 PM
Thanks for the reply Greg.
I tried hitting the same area with a 3M Scotch and 80 grit sanding pads. It looked a little better but wasn't totally gone so I hit it again with the sandblaster. The picture is attached. There's still discolored pitting so I'm not sure where to go from here. I'm not afraid of a little elbow grease so I can keep sanding. I just don't want to take too much metal off.
Old 02-24-2013, 08:47 PM
You will always have the shadow of the pitting, you just need to get rid of the black oxide. glad I could help.
Greg
Old 02-25-2013, 04:57 PM
elitecustombody's Avatar
I agree with Greg. Get it all out before shooting primer.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 02-28-2013, 05:30 PM
DOOM's Avatar
DOOM DOOM is offline
Get it out rust never sleeps!!!
Mario
USCOLLISION
Old 02-28-2013, 11:22 PM
Thanks for the info guys. Seems like I'm using every sanding tool in the shop but I'm getting there! Talked to Barry at SPI today. I couldn't believe how much time he spent making sure I was comfortable with the whole process and understanding the differences in their primer products. Don't find customer service like that very often these days.
I'm hoping to have this thing in epoxy soon. Then it's back to sheet metal and more epoxy. Its been good taking a break from fitting the passenger side quarter. The Golden Legion quarter fit great everywhere except the trunk area. It looks as though it wasn't completely stamped for the deck lid or seal. I've got a few hours into it just to get it to go all the way on the car. Thinking about going with AMD when I order the rest of my metal.
Old 03-01-2013, 06:31 PM
Denvervet's Avatar
Denvervet Denvervet is offline
I'm no expert but have heard that the media used to blast paint and mild rust won't get the dark black oxides. One has to use a different media....like actual sand/silica which is much harder. You just have to be careful.
68 camaro, 572, tko
Old 03-04-2013, 01:47 PM
MX145, buy a small Speedblaster gun if you have only some small areas, playground sand works just fine for that, just make sure to wear a good respirator
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 03-05-2013, 03:21 PM
Thanks guys. I got it all out using a combination of wire wheels, sanding discs, and a small sandblaster using sifted playground sand. Epoxy's going on to seal it all up.
