Old 02-25-2013, 09:18 AM
strtcar strtcar is offline
I've got Earl's black braided hose on my TA. One of the first things I intend to do with the car when I start working on it again is replace all of it with hard lines and PTFE hose. The smell is terrible.
I agree, I will only use hardline if I ever redo my flex lines, the smell sucks.
Old 02-25-2013, 09:40 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
Just in case you were thinking about PTFE lines as an option, I just did an EFI fuel system install on my car and used both the Aeroquip S-TW PTFE hose and SuperGem fittings and the Earl's Speed-flex lined(static dissipating) PTFE hose and PTFE fittings. The Aeroquip SuperGem PTFE fittings are less expensive(aeroquip.cc) and easier to install, but the Earl's hose is less expensive even though it has the inner lining for eliminating static build up. Overall, the same price for both hose and fittings with Aeroquip being a little easier to install the fittings on the hose. Neither of these companies offer a black PTFE hose though. I know Pegasus does, but it's $$$. I think another company does also, can't remember the name.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 02-25-2013, 09:44 AM
DRJDVM's '69's Avatar
Ive used the Earls black hose and havent had any issues but have heard of some that have.
I plan on going over it with a "microscope" when I get the car back on the road this spring....I may change it out even if it visually looks ok on the outside..piece of mind
I just bought the 911 PTFE hose from Pegasus Racing for the Cuda...its nice but its frickin expensive. About 3x as much per foot. Im going to run alot of hardline but even just the short sections from frame to tank etc cost a pretty penny.
Old 02-25-2013, 09:59 AM
intocarss's Avatar
http://www.anfittingsdirect.com/part...854f4f508671d3
Old 02-25-2013, 10:04 AM
Why is that so dang cheap? Any experience with it?
Old 02-25-2013, 10:08 AM
intocarss's Avatar
I don't have any personal experience. I do know a couple of shops that buy from them and were happy
Old 02-25-2013, 10:29 AM
Lenie's Avatar
Lenie Lenie is offline
I've been using them w/o issue thus far. The black stainless is more like a lightly painted black.
Lenie
Old 02-25-2013, 12:27 PM
canrc canrc is offline
BlackWrap Braided SS PTFE Hose
http://www.techafx.com/catalog/49
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
