Old 02-26-2013, 12:30 PM
GMJim's Avatar
GMJim GMJim is offline
Thanks for the thorough explanation. Our original Blackjack was tested and didn't leak but over time as design changed to improve shift feel we started getting feed back of fluid weeping up through the shifter. Our re-engineered design incorporates a seal that will hold up even when power washed from the gear below. Anybody who owns one of the affected shifters can call me to discuss a replacement.
Jim Goodlad
Hurst Driveline Conversions
www.hurst-drivelines.com.
760-859-6635 Tech Department
[email protected]
"Specializing in Tremec TKO & T56 Magnum overdrive conversion kits".
#1 Tremec Elite Distributor!
#1 In Customer Service and Support!
Old 02-26-2013, 12:36 PM
parsonsj parsonsj is offline
Originally Posted by Sieg
In the rear mounting position neither shifter leak, they just weep a little.
That wasn't my observation. I had to stop by the drug store and buy maxi-pads to keep the car from pouring fluid all over the exhaust with the shifter in the rear position. And that was with a seal on the bottom. (one generation newer than the WL pictures above).
I'm hearing there is a newer/better seal on the way for the White Lightning, which would be their 3rd seal design trying to fix this problem.
John Parsons
Old 02-26-2013, 12:41 PM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
Most creative explanation for standing at the checkout line with maxi-pads that I've seen yet.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 02-26-2013, 03:47 PM
Sieg's Avatar
Sieg Sieg is offline
Jim Goodlad
[email protected]
Jim!
Welcome to Lat-g! Really glad to see you join the fold.
Lat-g'rs - Jim and I have had many conversations over the last couple of years, they began with researching my auto to T56 Mag conversion kit options and installation details. In all my years of customer service business he ranks highly in my book as one of the real good guys no matter the industry.
Did you use the one's with wings? Obviously the level of mechanical fit varies and the seal was basically worthless. Did you fill the trans level to the bottom of the fill plug hole? I've seen T56 specs that call for 4 qts. Mine will only take 3.4 qts. on level ground with 2.5* drivetrain angle.
Very Macgyverish!
