Old 02-28-2013, 11:05 AM
Tony@Roadster Tony@Roadster is offline
BBC... the guys in the shop definitely have it going on... Phil is smart and wont let me even turn on a welder...
Old 02-28-2013, 01:30 PM
huggerz's Avatar
huggerz huggerz is offline
Looks amazing so far....nice work!
Aaron
69 Camaro
Old 03-20-2013, 02:40 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
We have made a lot more progress on the car than the we have on build thread over the past few weeks. So, here is a big update to get this one brought up to its current state.
Here is the area of the rear footwell that needs to be modified for the frame rail to pass through. We have fabbed a sheet metal channel that is welded into the floor for the frame rail to pass through. We also add an extra body mount in this location.
A complete view of the required floor modifications to install the chassis into a stock body. You can also see the reinforcing plate with the hole drilled for the new body mount.
A view from underneath
The car was also fitted with deep wheel tubs. Here you can see the front corner of the trunk (that was modified on the previous page) has been welded up and ready for metal finishing.
www.roadstershop.com
Old 03-20-2013, 02:48 PM
Supporting Vendor
RoadsterShop.com
Assembly has progressed on the chassis in this picture and the body is ready to be mated to it for the final time.
The inner fender required a minor notch to clear the upper shock mount.
The rear frame bracket bolts up the the original rear leaf spring mount in the stock sub rail.
A little branding!
Old 03-20-2013, 02:50 PM
Supporting Vendor
RoadsterShop.com
New stainless exhaust system was fabbed up and stainless tank from Rock Valley was installed.
Old 03-20-2013, 02:51 PM
Supporting Vendor
RoadsterShop.com
A few suspension detail shots.
Old 03-20-2013, 02:57 PM
Supporting Vendor
RoadsterShop.com
And the completed product outfitted with a new set of Forgeline ZX3P's with Matte black centers and polished hoops that really set the car off. We were extremely pleased that the customer took our recommendation to replace the directional billet wheels with the new Forgelines.
