Old 03-02-2013, 11:37 PM
David Pozzi's Avatar
Who makes the accessory drive? How is the alternator to rack clearence?
http://www.PozziRacing.com
Old 03-03-2013, 02:48 AM
WILWAXU WILWAXU is offline
Looks like a factory 4th Gen F-body setup.. with some very cool detailing.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 03-03-2013, 08:31 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
David- The drive system is out of a 2006 GTO.. & the alternator is very close to the lines on the rack n pinion but we are looking @ making some kinda of custom fitting .. I really like the alternator low as on this system but @ times can be difficult to run due to power steering lines & when running engine cooler lines..
I really perfer to run stock GM track systems..
here is a picture of the custom fitting that were done for the power steering pump... A banjo for the pressure & -10 for the feed on fluid to the pump.. Custom tank is in design right now...
Cris Gonzalez
Old 03-03-2013, 09:01 AM
Cris@JCG's Avatar
Here is another preferred GM product we like using here @ JCG.. On our T56 Magnum conversions we use the F-body/GTO clutch throw out bearing & like to enhance it with the option to remote bleed it & for plumbing with transmission removal make our own adapter to quick dis-connect the lines from the transmission..
Cris Gonzalez
Old 03-03-2013, 09:49 AM
Chris, your threads are a study of automotive engineering, I love ready through them. I always learn something new!
Old 03-03-2013, 10:39 AM
Richio1's Avatar
Richio1 Richio1 is offline
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Cris@JCG's Avatar
Thanks Al!
Cris Gonzalez
Old 03-03-2013, 11:06 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Love this car, keep up the good work!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-13-2013, 08:38 AM
captainofiron's Avatar
captainofiron captainofiron is offline
Originally Posted by Cris@JCG View Post
Where did you guys get that rear suspension set up from? Is it a custom job?
Old 03-13-2013, 08:55 AM
frankv11's Avatar
frankv11 frankv11 is offline
hey chris , I'm still eyeballing that ac compressor mount pulley system. when i get some time on my hands I may attempt to steal your idea
