Old 03-04-2013, 10:51 PM
CarlC CarlC is offline
Thanks for the kudos Dave!
I agree completely with your statements about fueling. The fuel requirements of today are not the same as your grandfather's Chevrolet.
Mayhem was a bit of a challenge with the dual ZL1 fuel modules, but the use of a Hobb's switch to control when the second fuel module is activated (still using PWM) cured some of the hurdles. The VaporWorx control system can handle three ZL1 fuel modules @ 100% DC from a power standpoint, so if you really want to crank it up......
Another method to control the relay would be to use the output from an aftermarket ECM that sent a signal at a specific MAP setting. This would work for aftermarket ECM's. I don't believe GM ECM's have this capability.
http:www.vaporworx.com
