Old 03-06-2013, 09:37 PM
Apogee Apogee is offline
Originally Posted by Moparigno View Post
thanks for the answer. I have a late model GM master cylinder (C6 Corvette). It should have (2x) M12x1.0 SAE metric inlets. Do you know if they require bubble flares as most of EU cars ?
The C6 Corvette MC actually has M12x1 metric inverted flare outlet ports, not bubble flares. FWIW, the C5 Corvette MC's were bubble flares, but only the '97 was (2x) M12x1, whereas the 98-04 were (1x) M12x1 and (1x) M12x1.5, the latter of which can be difficult to source suitable tube nuts.
Since you said you have the C6 master cylinder, a quick look inside the ports will confirm what they are
Tobin
KORE3
www.kore3.com
