Old 03-10-2013, 08:28 PM
1fstbird's Avatar
1fstbird 1fstbird is offline
Default oxidation on primer
hey, I was wondering if anyone else has had a problem with oxidation or a white foggy substance that shows up on the primer after you wash it. I have a hot rod satin black primer. I painted my chevelle and never had any of these problems but on this car it always gets worse every time I paint it.
EhlersRacing
Old 03-11-2013, 09:47 AM
elitecustombody's Avatar
Can you explain in detail what you're trying to do? What kind of primer you're using?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 03-11-2013, 01:00 PM
1fstbird's Avatar
I painted my car with hot rod black primer from napa. and I used the same stuff on my chevelle and it worked great. On the firebird it gets a white foggy substance that wont go away everytime I wash it. And only the parts that the sun is hitting gets it. Ive tried just water without soap and it still does it.
EhlersRacing
Old 03-11-2013, 02:22 PM
You can't expect primer to serve as topcoat ,especially if it's not catalyzed lacquer based primer .
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 03-11-2013, 03:24 PM
Denvervet's Avatar
Denvervet Denvervet is offline
UV breakdown of surface chemicals. Most primers aren't UV resistant. On top of that rattle can primers usually aren't waterproof....they're porous for a reason. Epoxy primer is the only primer that is waterproof I am aware of.
68 camaro, 572, tko
Old 03-11-2013, 07:01 PM
1fstbird's Avatar
it is a epoxy primer im not sure of brand its a Napa brand though.
EhlersRacing
Old 03-11-2013, 07:02 PM
1fstbird's Avatar
is there anything I can do to stop this Uv breakdown I don't want to paint it yet because the body isn't perfect.
EhlersRacing
Old 03-11-2013, 09:26 PM
Shoot a coat of clear
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 03-12-2013, 11:44 AM
1fstbird's Avatar
how do I get that foggy substance off before I do this. Should I use a clay bar? or really fine sand paper?
EhlersRacing
Old 03-12-2013, 01:34 PM
Try red scuff pad
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
