Old 03-19-2013, 02:07 PM
cocoabill cocoabill is offline
Default Need help with PWM Fan module wiring
Has anyone got a PWM fan module to work? I have an LS2 motor from an 05 vette that I would like to wire with PWM fan control. I have the correct module for the E40 ECM but can not find the required pigtail or a wiring diagram that matches the module.
There are 4 main vertical pins on the module 1-4 labeled M-, 31, 30, and M+ there are 3 horizontal pins 5-7 that are not really labeled but may be PWM input.
I have attached link to an image of module.
Anybody know how this is wired and the part number for the connector?
Thanks for your help.
Bill
Old 03-19-2013, 05:13 PM
Getting closer at least I know what it looks like
Old 03-20-2013, 05:16 AM
mikels mikels is offline
M- = Ground to fan motor
M+ = Power to fan motor
30 = Battery power (fused)
31 = Ground
Pin 6 = PWM input (in your case - E40 controller - J1-36)
Connector is sold as part of fan harness, which is part of cooling fan assembly - Part # 15819952 (AC Delco 15-80657). I found a few connectors separate years ago, but have since used them all.
Old 03-20-2013, 05:38 AM
Thank you very much, now for the connector hunt.
Old 03-20-2013, 07:35 AM
samckitt's Avatar
samckitt samckitt is offline
Other end of the connector looks like this;
I found it on the web, I dont have one. Looking though.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-20-2013, 07:42 AM
Thanks let me know, I found a motor with one on eBay, but kind of hate to buy a motor just to get the connector.
Bill
Old 03-20-2013, 04:11 PM
samckitt's Avatar
Bill
I didn't have any luck finding a new connector.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-20-2013, 04:30 PM
Thanks for looking, I bought the fan motor with connector on eBay, figured having a spare fan motor could not hurt.
