Old 03-21-2013, 05:28 AM
214Chevy's Avatar
214Chevy 214Chevy is online now
Good idea on the shifter. Priceless pic of the grandson in the seat. One day he'll see that pic and be amazed at when he was a baby sitting in the seat of the car that grandad will give him.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-21-2013, 09:24 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Default Hydraulic clutch install
Converting from the original mechanical Z-Bar clutch linkage on the Camaro to the hydraulic clutch set up turned out to be quite a bit more work than I expected. It seems like it would be easy, but it required a lot of work up under the dash in hard to reach areas... It was difficult to find the correct fittings for the plumbing... and it took quite a bit of time to gather up the right combination of parts to get the correct spacing between the clutch fingers and the hydraulic throwout bearing.
I purchased the hydraulic clutch conversion kit from Hurst that had all of the components. I bought their complete kit minus the throwout bearing. I already had a GM ZR1 hydraulic throwout bearing that came with the ZR1 twin disc clutch kit I bought from Katech.
Here is a shot of the complete kit. The kit came with an aluminum billet mounting bracket, a Tilton master cylinder, remote reservoir, and an adjustable length push rod, and hydraulic line.
Here is the GM ZR1 throwout bearing that came with the clutch kit from Katech. It turned out to be difficult to find a hydraulic line with the correct fitting to plug into the quick disconnect fitting on ZR1 throwout bearing (black plastic piece). I bought two different lines and neither one fit. I ended up cutting off the quick disconnect fitting and converting to a 4AN male fitting. A local hose vendor silver soldered on the AN fitting.
These are the two hoses I bought that didn't fit... one was to big and one was to small
This is a picture of the old fitting cut off and the new 4AN fitting silver soldered on
First step on the install was to pull the brake master cylinder and install the clutch master cylinder and bracket
Next I pulled the clutch pedal out of the car so I could drill a hole for the clutch pushrod clevis pin. The hole has to be in the exact right position so the rod doesn't bind up when you push the clutch in. The kit had instructions with dimensions of where to put the hole.
Next I made an adjustable hard stop for the clutch pedal. The hard stop is required so you don't damage the clutch master cylinder. From my understanding you don't want the plunger piston to act as a stop for the clutch pedal... this can damage the internals. Hurst recommended a hardstop be installed behind the clutch pedal.
The hard stop I made started out as a piece of 1" square tubing, two 3/8 nuts, 3/8 bolt, and a washer.
Clutch hard stop installed on the firewall
This is a shot of the clutch arm bottomed out on the stop. I set the stop height so the clutch pedal bottomed out on the stop just before the end of the stroke on the clutch master cylinder pushrod.
Then I installed the remote reservoir for the clutch master cylinder and then re-installed the brake master cylinder.
Finally.. I made the connection from the throwout bearing to the clutch master cylinder.
Now that the job is done I'm really glad I converted from mechanical to hydraulic clutch. I wasn't sure if was a good move or not. The clutch pedal effort is less now and it has a great feel! I have the ZR1 clutch with the heavier springs (20% more grip) and the clutch takes very little effort to depress. Also, with the hard stop and adjustable plunger, I was able to fine tune the position of where the clutch begins to engage. Another plus is there is more clearance around the headers... no more pivot arms and links.
That's it for the clutch install... Hope this helps for anyone thinking about converting.
While the car is up on the jack stands I plan to change the shocks from Bilstein to the new Hotchkis Tuned Fox shocks... and change the front upper ball joints to Proforged 1/2" taller than stock ball joints.
Also I picked up some new valve covers.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 03-21-2013, 09:30 PM
DaleTx's Avatar
Thanks, he's my first grandson... he looked pretty happy in that seat
Mario Andretti
Old 03-21-2013, 11:14 PM
intocarss's Avatar
Great build and write up Keep it coming
Old 03-22-2013, 06:55 AM
fleet's Avatar
fleet fleet is offline
X2.
This is textbook stuff...well done Dale.
Old 03-22-2013, 07:09 AM
coolwelder62's Avatar
Wow!!!! This is an awesome build thread.I may have learned something from it.I was wanting to use a ZR1 clutch set up on my next build.Thank's for the great info.
Old 03-22-2013, 09:12 AM
Sieg's Avatar
Sieg Sieg is offline
Great write up Dale........and exceptional work!
Old 03-23-2013, 08:40 AM
DaleTx's Avatar
Originally Posted by compos mentis View Post
X2.
Thanks guys... much appreciated
Coolwelder... I ran the ZR1 twin disc clutch for a few months last year with my Muncie before doing the T56 Mag swap. I can tell you that it is absolutely the best clutch I've had yet... and I've tried quite a few... you won't be disappointed.
Mario Andretti
