Old 03-21-2013, 11:28 PM
sixnina's Avatar
sixnina sixnina is offline
Start with the basics and take it from there.
I'd take it off, pull it apart, inpect, clean it out, and then blue print it by writing down the jet sizes, power valve number, squirters, accel cams.
With that large cam I'd say it would need more like a 4.5 power valve, maybe less. It should be half of your vaccum reading at idle. Make sure you are utilizing the 4 corner idle by backing the throttle plates down to 0 and them opening them up evenly until you get close to your desired idle speed. You may need to have the primary open slightly more. Your idle mixture screws should all be the exact same amount out. Tune them to your highest idle or vaccum.
Then move to jets and accel cams/squirters.
Thanks Todd I will try these things and get back to you guys thanks again for the direction.
Shane
Old 03-21-2013, 11:58 PM
intocarss's Avatar
http://tgsperformance.com/holley.htm
Old 03-22-2013, 12:05 AM
FETorino's Avatar
FETorino FETorino is offline
282 advertised dur in a 383 isn't that big a cam, only 235ish @ .50 so unles it has a real narrow LS like 107 the 6.5 pv should be fine.
Most 4779 dps metering are pretty rich at idle and right off idle so keep that in mind.
Rob in SoCal
