Old 03-23-2013, 07:01 AM
[QUOTE=Roberts68;471712]There are varying reasons. One plus for behind the right rear wheel is greater weight transfer to rear, and maybe some cantilever effect offsetting driver weight if you use your imagination. I didn't make it up, I read it.
One con for that spot was brought to my attention in CarlC's Honor Flight Camaro update thread is the possibility of collision becoming fire/arcing.
Crash = bad, crash then fire = worse.
Mine resides at right rear presently. If I relocate it will be far enough inboard to allow for future mini tubs... just in case. As it is though I thought I was smart securing it through the double layer at the frame rail.
Look up Camaro XV, Mayhem, or Red Devil... if one spot versus the other truly makes more sense from an engineering perspective you will see where that jn those.
