Old 03-27-2013, 09:36 AM
Sieg's Avatar
Sieg Sieg is offline
BTW ---- I still think you're a bit focused on the "amps" ----- and when learning --- your natural tendency is to weld real slowly.... building too much heat. When you turn your heat down -- way down -- you can focus more on the hand coordination of moving and dabbing and oh crapping....
EEEEEEEEEEHHHHHHHHHAAAAAAAAA
I've been trying to keep the amps low to reduce heat to the point of not having much puddle to dab into thus sticking the rod at the front of the puddle (oh crap) so I'd add a couple amps to the max range. Incorrect torch angle could come into play, tungsten grind, amp/speed/peddle/dab angle/vision, or, or, or.........
Old 03-27-2013, 09:59 AM
what are your amps ? I did a test piece of 16 ga and the amps ranged 27-34amps. Keep it up.
Old 03-27-2013, 10:34 AM
All of the above!!!
If you're rod is sticking into the puddle --- you might need smaller filler rod...
You know too --- and I write this for everyone --- not just Sieg.... Torch size has a lot to do with TIG welding.... of course - like most things - when you get good - you can weld with anything and just make adjustments.... but if you're welding on small thin gauge stuff.... then you need a small torch to go with that work. Like using a huge crescent wrench on a 1/4" nut.... if you think of it that way. Small = thin = delicate = pieces you have to use the small thin delicate torch / tungsten / fill rod.
Note that the CK site rates torches in amperage max....
http://www.ckworldwide.com/master.htm
My torches are all flex head... I like to be able to bend the head around to suit my work angle - which sometimes are just two pieces laying flat on a table!
Old 03-27-2013, 11:43 AM
Sieg's Avatar
On the 16 ga stainless my machine was set at 32-34 max amperage. 1/16 tungsten, 1/4" stick out, pyrex gas lens, flow 11-12 CFH........... not sure about my grip pressure, heart rate, breathing pattern, and bio-rhythms.
Old 03-27-2013, 11:45 AM
Sieg's Avatar
I'll mention that to the wife.
Old 03-27-2013, 03:18 PM
ccracin's Avatar
ccracin ccracin is offline
You need to make sure your wallet is in the same pocket as the hand you hold the torch with! Thus is key!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 03-27-2013, 09:08 PM
Great point....
Old 03-27-2013, 09:17 PM
She'll tell you, "you need more rod"....
That's a given.
Adding fill isn't sex -- you don't need to try to hit bottom. Hitting the bottom of the puddle will cause the rod to stick... but you already knew that. HAHAHAHAHAHAHAHA
Old 03-27-2013, 09:55 PM
Sieg's Avatar
That's a given.
More Rod?
Old 03-27-2013, 09:56 PM
Sieg's Avatar
How much money in the wallet before this has an effect?
