Old 03-29-2013, 05:42 AM
ClassicCustomConsoles's Avatar
ClassicCustomConsoles ClassicCustomConsoles is offline
This console will fit 67-68 Camaro's. I discussed with a 67 owner the width at dash and height when I designed the console. Console lines up with a/c, ashtray etc. The optional Dash Panel I have fits over that area bringing your dash out 4" at bottom flowing into console. You may have to trim console to fit your dash.
Old 03-29-2013, 06:02 AM
130fe 130fe is offline
Smile
Do you have any pictures of the "optional" dash panel? I looked on your website and didn't see it. Does it fit over the existing center dash area and transition into the console or what?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-29-2013, 11:12 AM
Default Dash Panel
I purchased a dash panel online from a Camaro site it"s a stamped piece of tin allowing you to eliminate part or all the items. I just made it a different angle. You can attach it to the bottom of dash as existing piece counter sink bolts up top into existing holes cut console to fit under panel. Bottom of this page.....http://www.classictruckconsoles.com/...inkholders.php
