Old 05-23-2006, 03:35 PM
gunmspec gunmspec is offline
Default rally wheels on 63 vette
Just wanted to start saying hi to everyone. Im new here. i was wondering what arer the biggest size wheels i can put on my stock 63 vette. If i can go bigger with susp mods then what mods are required? thanks
Old 05-23-2006, 04:44 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
not so much a suspension issue as there is just no room in the wheelwells for big stuff.
ours (1967 convertible)has 15x6's with 215/70's, and it's pretty much done.
Old 05-24-2006, 12:48 AM
so i coudnt run 17" rally wheels with the right offset? ive seen so many pics of c2 vettes with big rims
Old 05-24-2006, 08:09 AM
SLO 65 SLO 65 is offline
Default c2 corvette
gunmspec,
If you use an aftermarket "offset" trailing arm you can fit an 8" wheel in the rear of a 1963-67 Corvette. The wheel diameter (17" in your case) doesn't matter as much as the diameter / height of the tire. I've seen a 1963 SWC with offset trailing arms fit 20x8 wheels with 225/30R20 (25.5" tall) tires. Many of the resto-mod guys use the stock 245/45R17 (25.7" tall) C5 front tires on the rear of their cars.
This is a huge topic over on the Corvette Forum, may I suggest searching "17 wheel" in the C1-C2 area.
Nick
Old 05-24-2006, 08:11 AM
jy211's Avatar
jy211 jy211 is offline
sell your car to me
Old 05-24-2006, 12:03 PM
thanks guys for the help. just got the car its been in the family since i was 5 so sorry no selling here. again thank you
Old 05-24-2006, 02:26 PM
also does anyone know what brake upgrades can be done
Old 05-25-2006, 07:37 AM
Default brakes
Wilwood 140-5329 or
http://www.hotrodsusa.com/store/brakescorvette.html
Corvette Forum - Really!!!
Old 05-25-2006, 08:43 PM
JayR JayR is offline
Lateral-G Supporting Vendor
There's a trick for making a narrowed de-arched rear spring to get it dropped down I've seen done before. Disregard if it's common knowledge as I'm not a Corvette guy but wanted to make sure if you w ere going up in wheel diameter that you went down in ride height because wheels and stance are everything! Good luck and be sure to send pics!
Old 05-26-2006, 12:44 AM
thanks alot guys. will do
