Old 03-31-2013, 10:37 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Default Can I integrate Speedhut gages to Holley Dominator
I have Speedhut gages, can I integrate them with a Holley Dominator system, or do i need to run separate sensors ?
Greg
Old 04-01-2013, 05:13 PM
Come on guy's, some of the guru's on here must know.
Greg
Old 04-01-2013, 05:42 PM
Have you try contacting Speed Hut? They may already know the answer from other customers having been in your situation.
What gauges are you trying to integrate? Which ones does the Dominator system actually use?
Old 04-01-2013, 06:03 PM
carbuff's Avatar
carbuff carbuff is online now
I don't know if you are a member at PT.com, but there is a thread which is monitored by a Holley support person (Derek) who may be able to help...
http://www.pro-touring.com/showthrea...-Inside-Please
I don't have a Dominator setup myself, but I do have an HP EFI. Based on my reading of the manual, I don't think there's a way to do this. The Holley setups do drive CAN bus outputs, and recently Speedhut announced gauges that take CAN inputs. But I have no idea if the two have been tested together...
I am about to start wiring up my gauges myself. I'm going to wire them to a second of sensors on the engine. I will drive the tach from the HP EFI (it can do that), but everything else will come from dedicated sensors.
Good luck!
Old 04-01-2013, 06:06 PM
carbuff's Avatar
I forgot to mention that Holley has a support website:
http://forums.holley.com/forum.php
You might try searching there also...
If you find any different answers, I would be interested in knowing also!
Old 04-01-2013, 06:24 PM
Thanks guy's
I will try Speedhut and the thread over at PT.
Greg
Old 04-12-2013, 10:50 PM
tobenk tobenk is offline
I think u can tie ur input wires in with the wires for the computer and they will work but i have mine wired up spearate.
