Old 04-07-2013, 09:31 AM
Apogee Apogee is offline
Everybody seems to have an opinion, and here's mine...a wheel stud is intended to be in pure tension, not tension plus bending per basic fastener theory and best practices. By running a 5x120mm wheel on a 5x4.75 hub, or vice versa, you have a .012" [.3mm] difference in absolute position of the lug nut seat versus the wheel stud. The end result is a wheel stud with about 20-25% higher internal stress when torqued to the same level as a stud in pure tension, which equates to a 20-25% loss in factor of safety. If you're okay with this, as many are, then go for it, but to say that the two different patterns are the same thing and interchangeable is not accurate. Just because the consequently higher wheel stud stresses may not lead to failure in many instances, that still doesn't make it right.
Just my $.02,
Tobin
KORE3
www.kore3.com
Old 04-09-2013, 06:18 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Just my $.02,
Tobin
KORE3
Tobin, of course I don't know the engineering dynamics of stress versus pure tension and all that jazz about percentage loss. All I know is the wheel fits. Therefore it is interchangeable. Hahahahahahah!! Just giving you a hard time Tobin.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 04-09-2013, 10:00 AM
Fair enough and I appreciate the hard time, however I can make just about anything fit with a big enough hammer, but it's not necessarily something I would recommend. As with most things, it's ultimately up to the car owner to decide what they are or are not willing to run on their car, but the more educated that decision is when it comes to safety items the better, IMHO.
Tobin
KORE3
www.kore3.com
