Old 02-26-2013, 12:08 AM
G4CERAT's Avatar
G4CERAT G4CERAT is offline
Default Bracing up...
Installing the bracing. Wasn't quite sure what to do with the trunk sheet metal and the firewall so I left a lot of it rough.
Dan G. aka G4CERAT
Old 02-26-2013, 12:12 AM
G4CERAT's Avatar
I added some sheet metal to the inside of the rocker area before setting the body on the frame.
Dan G. aka G4CERAT
Old 02-26-2013, 12:30 AM
G4CERAT's Avatar
Default Sizing up the frame.
This was the first go around with the frame when I first received it...it's changed a lot since. The wheels were built for test fitting...
This was all really rough just to see what I was working with. The body came back off shortly afterward.
Dan G. aka G4CERAT
Old 02-28-2013, 11:48 PM
now your talking. Looks good. Just the right height to be called crazy.
I like the rear glass but stock looks bad ass flush mounted.
Old 03-07-2013, 10:19 PM
G4CERAT's Avatar
Haha...I see I was beaten to it.
Thanks Vince
Dan G. aka G4CERAT
Old 03-07-2013, 10:52 PM
G4CERAT's Avatar
Default Oil Pan Mod
So, since I decided to put the biggest motor I could get my hands on in a frame that was built for a small block, I had to notch the pan to clear the lower control arm mount on the pass. side. I made the cut and prepped it and had my buddy weld in the new panels. It was a good fix and came out clean. The next plan is to cut it in half and take about an inch out of it for some piece of mind while going down the road...it hangs low.
Dan G. aka G4CERAT
Old 03-08-2013, 07:17 AM
Payton King's Avatar
Default Very cool build
Looking forward to the continued progress
Old 04-13-2013, 05:30 PM
syborg tt's Avatar
Awesome build - looking forward to more build pictures
marty-mj
Old 04-13-2013, 05:54 PM
fleet's Avatar
fleet fleet is online now
X2.
Old 05-22-2013, 02:32 AM
Dan - how's it going down there?
