Old 04-13-2013, 09:35 AM
Bucketlist2012's Avatar
Bucketlist2012 Bucketlist2012 is offline
I called my retired buddy Ray --- said "we have a building to take down -- and rebuild".
We disassembled the entire building and started over. It was so easy a 3rd grader could have built it.
Better you take it down and rebuild it......Because it was coming down anyways...Sooner or later
Luck is the meeting of preparation and opportunity
Pro Touring 71 Z/28 in training
Soon to be crazy
Old 04-13-2013, 10:20 AM
This is the kind of stuff that just absolutely drives me INSANE!!!!
Note the nut isn't tight..... and then in the second picture you'll see why! Look at those galled up threads! OMG.....
Here's another quality example of "you're fired!".......
I was wondering why there were so many WASHERS in an unopened bag.....
There is supposed to be a "rocker nut" UNDER the nut and washer.... these tensioning cables are used to keep the building square in windy conditions... because the building will rack...
Let me ATTEMPT to explain this..... This is a back corner post/upright.... it's the outside corner. When THEY put this together --- 3 guys standing around staring up -- so I went out to see why they're all staring and scratching their sack..... and they're discussing cutting the brackets off where they extended beyond the angle the next day and re-welding the part that extended beyond the angle - around the corner so they could put on the board that should come from the back side... In other words -- they had run the board on the side (on the left of this picture) of the building all the way to the end of the bracket and attached it -- then they couldn't land the backside board anywhere since they'd covered up the entire bracket... their SOLUTION was to remove the boards -- cut half the bracket off - and re-weld it to the back side of the angle upright.
I looked at this "problem" and said -- why don't you just unbolt the board and slide it back to where the end meets the corner of the angle upright --- and then you'll have a place for the back side board to land (NOW AS SHOWN IN THE PICTURE).... It was a total "huh?" for them. I had to explain it TWICE.
The next day - they were fired.
Old 04-15-2013, 12:06 PM
Tony_SS Tony_SS is offline
That is why I have a VERY hard time hiring ANYONE.
Skull Daddy Graphics
Design / Apparel / Vinyl Graphics
Old 04-15-2013, 01:15 PM
Shmoov69's Avatar
Shmoov69 Shmoov69 is offline
Man you're picky Greg!!! LOL!!
Really, it's so freakin difficult to get anyone that has a single "give a crap" bone in thier body!! Especially in construction! My guys can't stand that I'm so picky about things, but I tell them over and over "if I'm going to pay someone to work on my house or work on my car or whatever, then I want it right"!! I EXPECT that for my customers. No ifs, ands or buts!! I'm in commercial roofing and needless to say, it's not too glamorous and the labor "pool" is not very deep!! LOL!! But good enough is not an option if someone is paying me.
Jimmy
69 Camaro - Twin Turbo'd
58 Nomad -348 Baby Rat
www.fquick.com/shmoov69
