Old 04-22-2013, 08:24 AM
srh3trinity srh3trinity is offline
Thanx guys!
Stephen, very little work was done to the VFN hood. Jake at JRS painted and installed it, but from the pictures that I have of the work being done, there were just a few little touch-up spots on it. Nothing was really done along the edges to work on gaps or fitment. All things considered, I think it's fit great!
The only issues with it are that it's not strong enough to force the shaker scoop seal 'down'. By that I mean, the seal is pretty stiff, and if it sits up high at all (which mine did before), the hood isn't going to flatten it out. My hood bulged a little in the middle because of it. And thus my need to find a drop shaker base...
I am going with a flat hood so I shouldn't have any problems. I want to do some hood mods.
Stephen
Old 04-22-2013, 08:32 AM
gerno's Avatar
gerno gerno is offline
Car's looking really good. The engine bay and gauge layout are super clean and mean business. Looks killer
Old 04-22-2013, 09:52 AM
carbuff's Avatar
carbuff carbuff is offline
Thanx! Come a long way in a couple of weeks.
Old 04-22-2013, 06:38 PM
qnitro's Avatar
qnitro qnitro is offline
OK here is what I got.. from the bottom of the base.. to the top of where the carb mates to base.. 1 3/8...
here are pics is this what you needed??
Eat or be eat'n
Old 04-22-2013, 07:17 PM
carbuff's Avatar
Just one more measurement if you can...
On the outside of the base, the distance from the bottom to the lip where the shaker attaches. I think from the WFO pictures that this is where he gets the actual drop from.
Thanx!
Old 04-22-2013, 07:50 PM
qnitro's Avatar
That is 1 3/4 in
Let me know if you need anything else..
Kevin
Thanx!
Eat or be eat'n
Old 04-22-2013, 08:14 PM
carbuff's Avatar
Kevin,
That is what I needed! Thanx!
Unfortunately, the WFO base doesn't drop quite as much as I had hoped. Given your two measurements, the shaker ring is 3/8" higher than the carb base. I was hoping it would actually be at the same height, or preferably even lower...
On my current setup, the shaker ring is 1" higher than the carb base, and I had hoped to get that down to even, if not even lower.
From an old email that I received from PTFB, their dimension from the carb base to the bottom (your first measurement) is 2", but their side height (second measurement) is minimum of 2.5" (they have 3 different heights available). So their setup puts the shaker right about 1/8" higher than the WFO.
It almost sounds like I need to buy the PTFB and cut 1/2 - 3/4" out of it to reposition the shaker ring down to where I need it to be. Since it has more drop, I will have more clearance on the air cleaner to shaker at the top side this way...
Thanx again for the help, I'll update here once i figure out the right solution!
Old 04-22-2013, 09:51 AM
carbuff's Avatar
I think you'll find it a good starting point then. The only word of caution is that there isn't any real support in the middle of the hood, so you need to be careful about adding a lot of weight to it. It's pretty flexible through the center area, with just a support around the boundary for the hood latch (which I'm not using) and the hinge mounts.
