Old 05-29-2006, 10:38 AM
bwindy bwindy is offline
Default Big Stuff 3 Fuel Injection
Is anyone running the Big Stuff 3 fuel injection system. How is it to work with, where was it purchased, and what type of engine is it being run with? I am trying to decide what system to put on my car (big block Chevy with Procharger).
Thanks for the info
Brian
Old 05-29-2006, 11:02 AM
I do not run the Big Stuff 3, but they are great systems also. I have spoken to many happy Big Stuff owners. We have had great success with the FAST XFIs and have a top tuner that works closely with us which makes the decision difference here. We are putting together complete conversion set ups with manifold, rails, throttle body, electronics, etc. And ProChargers. We are firing up a ProCharged, Fast injected, 455 Pontiac in a couple hours. That Pontiac uses a Serpentine accessories drive, along with the ProCharger (I believe a first). We are also doing a big block Chevy with a F1, Serpentine set up and a FAST. These will be available in kit form very soon.
Old 05-29-2006, 01:34 PM
jonny51 jonny51 is offline
Sorry to get off topic but what is that 455 poncho in?
Old 05-29-2006, 02:54 PM
Blown353 Blown353 is offline
I had the chance to mess with a few new to me EFI systems over the last couple of weeks including the BS3 and XFI and had a real eye opener concerning the "homegrown" US-sourced EFI stuff.
The FAST, XFI, and BS3 are good "domestic" boxes-- meaning they're somewhat basic and limited on options but will do a fine job if setup and tuned properly. The BS3 is pretty skimpy when it comes to documention, help, and support provided with it but it is a good box. The XFI is much better from a documentation standpoint and offers a very comparable featureset compared with the BS3.
However, I also had a chance to mess with an AEM and an Autronics box, and man oh man are they leaps and bounds ahead of the typical Gen VII/FAST/XFI/C950/BS3 and the price is very comparable. The AEM and Autronics boxes are much more involved to setup but there are a *TON* of user configurable features in them that the "domestic" EFI boxes don't even think about offering. You can run darn near any sensors/inputs/outputs you like and you can configure them on your own; linear voltage, PWM, etc. They also offer acceleration-rate based traction control, multiple input and output triggering options you can configure yourself (no sending the box back to be changed like a FAST), way more advanced temperature compensation tables (i.e. with the FAST you can only change fuel based on IATs, while on the Autronics and AEM you can not only change fueling but change timing and also drive a configurable output like PWM signal to drive a boost control solenoid to cut down on boost due to excessive IAT's.) They also offer flatfoot shifting via a clutchswitch input, antilag for turbo users, etc.
Absolutely no contest IMO. If I were re-doing my car again I would probably go with the Autronics box as I've heard some minor griping with the on-board injector drivers in the AEM box. My FAST works and drives well but there are several options I wish I had that it does not offer. The Autronics box would do everything I want and then some!
And as Frank said, even the best box will be a dud without a good tuner at the helm. I would base my decision on tuner availability and knowledge above almost all else, but do not limit your options to the "domestic" boxes; you're missing out on a LOT of good stuff if you do.
http://www.aempower.com/product_ems.asp
http://www.autronic.com/
Troy
1969 Chevelle
Old 05-30-2006, 06:09 AM
Speedster's Avatar
Speedster Speedster is offline
I have a serpentine belt drive on the Freebird. Had to have a custom balancer made by ATI to do it though.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 05-30-2006, 06:11 AM
Speedster's Avatar
Electromotive also makes the TEC3 system which is utilized on high horsepower machines.
-Bruce
Project "Freebird"
Dyno Video
Project Rides:
2007 Magnum
Old 07-20-2006, 06:17 PM
blown69 blown69 is offline
Default big stuff
i run the big stuff on my blown 509 with a bds 871 and bds efi.works great
jeff
Old 07-24-2006, 04:09 PM
67SSChevelle 67SSChevelle is offline
They are good systems but quite expensive. For a street car you can do just as well with stock PCM and harness then you can buy something like EFI Live or HPT
Old 07-24-2006, 05:09 PM
camcojb camcojb is online now
Bruce,
I am very un-impressed with the Tec 3 on a new purchase I made, and so was the original owner of the system. It appears extremely clunky and light years behind any of the others I've used. I am in the process of swapping it for a FAST I have sitting around, so if you'd like I'll be selling the complete setup and will make you a great deal! Has less than 400 miles on it apparently.
Old 07-24-2006, 06:07 PM
Originally Posted by camcojb
Bruce,
Heheheh... was wondering how long you were going to put up with it.
Sell the FAST and do an Autronic box... DO IT! You can even keep the current TEC3 crank trigger setup, which is a good setup by itself.
Just kidding. It will run just fine with the FAST, and since you already have it and have lots of experience with them it makes perfect sense. You'd be sitting in your shop scratching your head for quite a while with an Autronic box, it's a big step up in capability and complexity.
1969 Chevelle
