Old 04-23-2013, 01:49 PM
GrabberGT's Avatar
Originally Posted by coolwelder62 View Post
Ballistic fabrication has some cool conical spacers that will help with the binding.
You might could use a little more thread engagement as well. Especially if you start using that inner adjustment hole on the arm.
Chris
Its not a Vega!!!!
Old 04-23-2013, 03:42 PM
Bryce Bryce is offline
That was a test fit trying to get less bind. The longer was not much better. My plan is to quick release pin the arm attachment on and not adjust the link length.
Old 06-17-2013, 03:52 PM
Update:
New motor mounts.
I re-made the side plates from aluminum. This took some weight off the front end and gave more adjustment.
Old 07-13-2013, 11:46 PM
I spent the day dialing in the Falcon for the SCCA event next Sunday.
My front suspension is adjustable in every aspect and really allowed me to dial in the characteristics I will be trying this time.
I pulled in a little more caster and adjusted the suspension for more clearance with the inner fender. I also spent a lot of time measure my dynamic camber changes during turning. I now have 1 degree of negative camber gain at full steering angle. I ended up around 8.5 degree of caster and 2.5 degrees of negative camber. 8:1 manual steering is kinda tuff. Oh well I guess I will workout a little next week.
Tomorrow I will nut and bolt everything and the car will be ready for the 21st. See all the san diego guys out there!
Old 07-14-2013, 01:32 PM
Don't forget hose clamps and charging the go pro!!
Old 07-15-2013, 12:46 AM
FETorino's Avatar
FETorino FETorino is offline
Nice work. Can't wait to hear your impression of the changes you've made.
Rob in SoCal
Old 07-15-2013, 12:48 AM
Don't forget charging the go pro!!
yes!
Old 07-15-2013, 09:49 PM
Tomswheels's Avatar
Tomswheels Tomswheels is offline
As always, looking forward to seeing the beast in action Bryce!
67 Plymouth Valiant
69 Barracuda Convertible
