Originally Posted by BANKO
...Yes, I'm running the HPS pads, should have gone with the HP+ pads. Forget the noise and dust, I want higher CoF!
I'll be updating my brakes in the coming weeks to Wilwood W6A in the front and moving my Z06 PBRs to the rear. Trying to decide if I buy 4 sets of line pressure gauges or use a clamping force pressure tester. Has anyone used this tool?
That's a cute tool, but I don't know anyone who has one or who has even used one, so I can't comment on its worth in a toolbox for troubleshooting. It kinda reminds me of a valve spring tester to be honest. As for caliper pressure gauges, you should only need two since you only have two brake circuits, front and rear, and they should provide the same pressure to both calipers on the same circuit per conventional hydraulic principles. Alternatively, they make the brake pressure gauges intended to be mounted in the dash to provide feedback to the driver when adjusting in-cab detent proportioning valves and/or balance beam position with the remote adjusters.
As for pads, any "GG" friction rated pad is going to be a step in the right direction given a manual track application, so Hawk HP+, EBC Yellowstuff, Carbotech AX6, or something similar should provide significantly higher brake torques with less pedal efforts.
Tobin
KORE3
