Old 05-09-2013, 03:24 PM
67rstbkt 67rstbkt is offline
Originally Posted by BBPanel View Post
What I did won't solve your backing plate/bearing issue - you would have the same issue w/S10 backing plate - I was just pointing it out as a solution if you have LS1 caliper clearance issues. Also, I'll see if I took some pics but as I recall my bearing protruded just a little even with the flush mount ends, but nowhere 1/8". -Bob
Thanks, I got that; If you can post a pic of that so I can compare what mine looks like, that would be greatly appreciated.
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
Old 05-09-2013, 03:30 PM
BBPanel BBPanel is offline
Ok, just wanted to be sure I didn't lead you down a path to the same problem. I'll take a look but as I recall it was on the order of 0.030" or so.
Old 05-09-2013, 03:32 PM
I appreciate that. How did you deal with the bearing protusion, btw?
Old 05-09-2013, 03:48 PM
As I recall, I spoke w/Moser and they weren't concerned about it so I bolted it up and never looked back!
May not be as elegant but I suppose you could use washers on the t-bolts to mock up everything before having a 1/8" shim made or machine the backing plate. You could verify the axle offset needs that way too if you choose to user the spacer.
Old 05-10-2013, 09:24 AM
I started mocking it up, I see what you mean about the calipers. It's a tight fit. I'm wondering what would happen if I mounted them to the rear (clocked 180* from stock)?
I have not taken exact measurements yet, but it looks like my new axle would need to extend out (increased offset?) from the housing an additional 3/8" for this to work. I measured some washers I had and found some that were really close to 1/8" to space out the backing plate.
I based my measurements on a 98 Camaro I have access to; I figured that if I match those measurements, the brakes should be correct.
Old 05-10-2013, 09:35 AM
In my case it was an issue regardless of which side the caliper was on. Just depends on the shape of the frame.
Old 05-10-2013, 09:40 AM
Thanks, I'll take some pics as I get further into this mock-up. I'm pretty certain I have a little more space compared to a Nova, so I may be able to pull it off. We'll see I guess. I'm assuming the S-10 brakes you used mount the same way, correct?
I'm thinking my plan at this point should be do what I need to do to get the LS1 brakes to work and as a last resort, switch over to the brakes you used.
