Old 05-14-2013, 05:26 PM
Novette_71's Avatar
Novette_71 Novette_71 is offline
Default Poor Braking - Low Pressure 1971 Nova
folks,
i dont get it. i have a big problem with my brake setup, and i dont know what it is. maybe you can help.
i have a 1971 chevy nova protourer, 11" brake booster, 1" wilwood aluminum tandem master cylinder, dodge viper RT/10 calipers front, standard corvette C4 brakes rear.
big engine with low vacuum, so i have a CPP vacuum pump that starts working at 15" and stops working at 20".
with NO vacuum i get 500 to 600 psi at the caliper when pressing the pedal really hard. this is the value my excel sheet tells me i should have, so it is okay to this point. with the pump activated i get 1000 psi pressing the pedal really hard .... the difference between "with" and "without" brake booster assistance is too low. theoretically by calculation the booster should give me 900 psi alone ... it means on the road you have to press the pedal really hard to have stopping power.
also i recognize, that the travel of the pedal feels long until a first amount of pressure is build up. i was bench bleeding the master cylinder several times, as well as bleeding the lines and calipers, it makes no difference.
so how is it possible my braking prower is power assisted only slightly better than without the boost effect ???
A) Master Cylinder was bled, two front ports go to front brakes, rear port goes thru an adjustable pressure valve to the rear brakes.
B) Ignore the additional rubbe hose, the CPP pump is directly connected to the brake booster
C) For brake pressure checking I use a gauge in the caliper, for seeing the value from the driver seat there is a camera connected to my PC
