Old 05-26-2013, 08:15 AM
Old66Tiger Old66Tiger is offline
Yup, I was driving the car down the road before I pulled the front end apart and swapped the SpeedTech stuff over for the Ridetech stuff. The Speedtech with factory spindles needed 3/16" shims to get -0.5 degrees of camber at the same ride height. I made up 5/8" of shims out of oak (just to see where the camber would end up and I am still in the positive area. Car is not dragging weeds. About 2" lower than factory at best.
Apparently, these arms just went through a complete re-design. I also now need to grind my inner fenders to allow clearance for these arms.
Old 05-26-2013, 09:10 AM
Blake Foster's Avatar
Now why would you go and do that???
Blake Foster
www.speedtechperformance.com
Old 05-26-2013, 09:26 AM
coolwelder62's Avatar
Did you get the right part# of a-arms.Give Darren @ridetech acall.I'm sure someone there can figure out what needs to happen to fix the problem.
Old 05-26-2013, 01:45 PM
Not sure. I looked at their website and it appears that the pictures listed are for an older design like what was used on the 66 GTO for V8TV. I saw in another post that they were going to setup their test chevelle with the newer design so it will be interesting to see if they ran into the same problem as I did.
Old 05-26-2013, 08:44 PM
HAHAHAHAHAHAHAHAHA good question!!!
Old 05-26-2013, 09:45 PM
clill's Avatar
clill clill is offline
Have you called Ride Tech ?
Old 05-27-2013, 06:27 AM
Holiday weekend...always my luck. I have a show this coming Saturday that I paid for in advance so I am hoping to get this ironed out before then.
Old 05-27-2013, 11:57 AM
I stand corrected on one of my prior posts. The Ridetech spindles are measuring only 0.100" greater than the factory spindles from the upper mounting boss to the ball joint hole. The arms measure almost 1/2" longer from the cross shaft to the center of the ball joint than the Speedtech arms. Add these two together and there is the difference.
Old 05-27-2013, 12:56 PM
Sucks to have long weekend problems, I hear you there! Hopefully it is something simple like old part number etc that they can correct for you. I will say, that Bret was extremely good getting an issue I had sorted out last week. I guess squeaky wheel gets it, but they had no issue helping me once I got the attention of the right person.
We are all curious though, why did you yank the Speedtech arms????
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 05-27-2013, 01:08 PM
Ron Sutton's Avatar
Would it make sense to go back to the Speedtech arms ... or wait until you talk to Ridetech Tuesday ?
