Old 05-28-2013, 12:45 PM
Dr.Acula Dr.Acula is offline
Originally Posted by Apogee View Post
Wilwood 6-piston like the Forged Narrow Superlite 6R? If so, then the track width change for the 140-9804 brake kits is +.38" per side relative to the OE track width. Ride height is the next thing to consider along with tire size/diameter since the two will both play a part in fitment, so measuring your fitment or mocking things up really would be your best bet.
My guess is that 5" BS won't be enough given your brakes and assuming a 245/255 tire with 25"+ diameter. You can always space a wheel outward to compensate for too much BS...going the other way is a bit tougher.
Tobin
KORE3
Yes, the Superlite 6R's are what I have up front. So you're saying 5" is too much backspacing? I thought I would need more backspace up front
