Old 05-28-2013, 01:56 PM
camcojb camcojb is online now
The problem I've seen is the bolt isn't long enough to get enough threads in the crank when the balancer is just starting to be pulled on; you run the risk of stripping the crank. I use a threaded rod with large nut/washer, and a roller bearing between the balancer and washer/nut. Bought all of that through McMaster-Carr.
Old 05-28-2013, 05:00 PM
Do it how Jody did his. If you try to use the old crank bolt, you'll damage the crank threads.
Old 05-29-2013, 05:16 AM
samckitt's Avatar
samckitt samckitt is offline
Go to Fastenal & get a piece of threaded rod & make an installation tool. I think it is 14mm x 1 thread (have them check with old bolt). Get some bronze washers, some segments of pipe for spacers & a couple of nuts & you are good to go. I did that & tonight can take a picture & show you if you like.
Basically something like this:
Scot
86 Monte SS
LS2/T56 Magnum
Old 05-29-2013, 07:14 AM
boostin05blacks boostin05blacks is offline
I just went to autozone and rented the installer tool. When your done you just return it. If you dont have autozone I'm sure there is another company like napa, pepboys. They almost all do rental. Also I splurged and bought the ARP bolt which can be reused compaired to the original which can not..
Old 05-29-2013, 08:38 AM
Code510's Avatar
Code510 Code510 is offline
Ahhhh okay. Thanks for the replies. What Jody said makes perfect sense.
I noticed on Ebay there is guys selling the 'installation tool' for $20 bucks. Theres a guy on my local craigslist selling one for $40 bucks!
I didn't think about autozone though...I'll have to go that route.
Thanks again for the help! You guys rock!
Old 05-29-2013, 10:11 AM
I like to use a hot plate and ove gloves. Works great be sure not to over heat it. 210 degrees tops.
Old 05-29-2013, 10:45 AM
Sieg's Avatar
Sieg Sieg is offline
You know way too many old school tricks for a young guy.
