  #18
Old 05-28-2013, 07:19 PM
Old66Tiger Old66Tiger is offline
Bret, Thanks for the response. I understand that things need to be made somewhat neutral and in the past the extremes were dealt with at the frame shop...to cure the sagging a-body frame problems. My car apparently does not have that problem. I worked on it a bit tonight and I think I have a good neutral alignment - enough to make it to the alignment shop without chewing up my tires.
Here are a couple of observations from the end user point of view.
1. I understand that the upper arm geometry re-design was to allow easier fabrication of the parts by allowing the tubing to be welded at a right angle to the bushing shell. This is good from the manufacturing side, but bad from the user side. The openings in the wheel wells of the GTO's are pretty narrow and requires some cutting to get them to fit. A triangulated design allows installation that is easy to achieve without tons of modifications. This is especially key after the car has been painted.
2. I like the off-set slugs for the cross shaft, but to be truly effective, these need to be included in the kit to allow them to be used at the time of alignment. My alignment guy gets a minimum of $100 every time the car rolls onto the alignment rack. Without these in hand, it can get kind of pricy and time consuming waiting to get a set of the slugs mailed to you.
3. A set of shims included with the kit would be nice. They cost about $0.030 each but are a bear to come by in small towns or places where the parts stores just can't get them. In my case, i need them to make it out of the garage and down the road to the shop. Without them, the tires hit the lip and I can't go anywhere. I got lucky, I found a source, but it took 8 calls to get them.
4. The offset cross shaft is a great idea and even more offset would be better. In the case of the Ridetech cross shaft, there is only 1/8" of additional camber that is achieved by rotating the shaft.
there might be others, but that is the start. Everyone in your organization was very pleasant to deal with and got back to me very quickly. Britt even e-mailed me late on Friday night with an answer to a question I had.
