Old 06-10-2013, 04:06 PM
syborg tt's Avatar
Default Strange C-clip Eliminator For Street Application
How timely. I was just thinking of messaging Tobin to see if I had any options with his parts should I decide to go with a C clip eliminator kit on my 10 bolt. Do you have any pictures or info you can share on the process, Marty?
Trey was kind enough to PM me what he's learned so I thought I would share it with everyone.
Strange has a new kit that they are saying is specifically for street applications that uses tapered bearings. Just thought I'd pass the info on since you said someone mentioned the kit was designed to go around corners.
here is the info and thank you Trey
STRANGE C-CLIP ELIMINATOR FOR STREET APPLICATION
http://www.competitionplus.com/drag-...t-application-
Strange Engineering, Morton Grove Illinois, introduces a new style, specifically designed for street and/or strip, c-clip eliminator for most 10 & 12-bolt GM car rear ends equipped with c-clip style axles. In the past, c-clip eliminators for these applications have been designed for drag racing, which use ball bearings. Ball bearing c-clip kits are fine for drag racing, but are prone to leaking and premature failure when used for prolonged street use. Our specially designed c-clip eliminator kit (A1033) utilizes Timken unit (tapered) bearings, which survive severe side loads and constant use.
The Strange A1033 also features two seals per axle shaft, ensuring a completely sealed axle end. Complete axle and c-clip eliminator packages are also available.
marty-mj
Old 06-10-2013, 06:17 PM
No problem. Ron and Jerry were helping me in my thread on building my 10 bolt up and they both passed that info on to me. Figured I better pass it on to you as well since you have the eliminator as well.
Line X looks good. I think that'll be the route I take eventually as well.
Old 06-11-2013, 04:29 PM
kennyd's Avatar
kennyd kennyd is offline
none of this bothers me , he never drives anything !
Old 06-17-2013, 09:58 PM
syborg tt's Avatar
Default 2nd Chance Camaro - Custom Works CF Front Bumbers
2013 06-17 2nd Chance Camaro - Custom Works CF Front Bumbers
www.2ndchancecamaro.com
Good Evening,
I really don't need to say much as they speak for themselves.
Pictures hosted by www.garagescene.net
marty-mj
Old 06-17-2013, 10:09 PM
Rick D's Avatar
Rick D Rick D is offline
Um me likey! So where did you get those??
Rick
Old 06-17-2013, 10:23 PM
syborg tt's Avatar
http://www.customworksproducts.com/
marty-mj
Old 06-18-2013, 03:28 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Front bumperettes looking good Marty. Now you gotta get the matching rear carbon fiber bumper too, you know?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-18-2013, 04:27 PM
syborg tt's Avatar
Not to worry it's on order the rear bumber is on order. I am also going to have the front spoiler, the new 3 piece rear short Spoiler and the rocker skirts made in carbon this winter and have them on for Sema.
marty-mj
Old 06-19-2013, 09:54 AM
syborg tt's Avatar
If you want I can bring them home so you can see them before I ship them to Kenny's. Or maybe I will bring them to your house when I come to see the Camaro.
marty-mj
Old 06-19-2013, 04:24 PM
Rick D's Avatar
Either way but yes I would like to check them out
Rick
